Thread: Coyote in a 33, CMCV question
    Port Charlotte, FL
    FFR's newest instructions for the Coyote in a 33 say
    "Remove the CMCV actuators and block off the vacuum feeds."
    "When standing in front of the engine, the left side CMCV shaft needs to be rotated clockwise and locked in place."
    "When standing in front of the engine, the right side CMCV shaft needs to be rotated counterclockwise and locked in position."
    My question is after taking off all the CMCV stuff, how do you lock in position? I left the bars in an tie wrapped the ball mount to the intake. Any other ideas?
    Only 1 vacuum feed needs to be blocked, right?
    Thank you,
    Henry
    Hey Henry. Most of the Mustang tuner sites have CMCV lockout parts for Coyotes. Pretty simple and not too expensive. They are different depending on which vintage you have. These are for the Gen 2. The is one source and also has some pictures that may be useful. http://www.modularmotorsportsracing....roducts_id=896. Assume you know they also need to be locked out in the tune or you'll get DTC's.
    I haven't done it, so don't know exactly what vacuum ports are left once you remove the actuators. That port on the back of the intake is for the vacuum source from the front of the engine. Wouldn't hurt to cover it, but also wouldn't matter if it were left open. Not sure what else they want you to.
  3. Thanks 65 Cobra Dude thanked for this post
    Port Charlotte, FL
    Thank you!!!
    Simi Valley, CA
    CMCV lockouts
    20190217_123719.jpg Here is what the CMCV lockouts look like on a 2018 intake manifold. The parts for a 2017 intake are similar, but not the same dimensions.
    The thing that confuses me is that the lockouts only allow the arms to be locked in one orientation, and that is different from what I understand the instructions to say...? The passenger side arm is locked clockwise when looking at it from the back of the engine, not looking from the front. The lockouts only fit one way, so am I just reading the instructions wrong? I can't imagine that MMR made a mistake?
    Keith
    Prairieville, Louisiana
    I just zip tied them closed. Their position at rest before you removed the actuators is wide open and where you want to lock them. I’d have to look at mine. I would have used the bars except my intake will be coming off to install the supercharger so I didn’t spend the money.
    '33 Hot Rod
    MK4 Roadster
    CMCV LOCK OUT 2015 - 2017 Mustang GT & Shelby GT350
    These Billet aluminum lockouts position and lock the IMRC (intake manifold runner control) in the full open position. Perfect for Supercharged and Turbo charged 2015 - 17 Mustang GT applications, transplant applications or applications using the SHELBY GT350 Manifold. This kit deletes all of the bulky actuators, sensors and vacuum lines for a cleaner look and lighter weight.
    Making a lighter shade of lipstick on the pig.
    MkIV #7854, Kit picked up September 2012, Coyote/BOSS 302 intake tuned at 488HP, TKO600, Center Force, Moser 8.8, driveshaft safety hoop, Stainless Header 4x1x4 headers, Gas-N-sidepipes, rad shroud, Wilwoods, NO PS/PB, heater/defroster, heated seats, wipers, Herb door panels, Dynamat Extreme sound/heat dampening, premium Rodtop top, Fast Freddie lexan wind screen, Nitto 555R, drop trunk battery, drop trunk storage,
    Dracut, MA
    Sorry for tagging onto this post but.....What about pre-2015 coyote engines? My 2014 does not appear to have any of that hardware.
    Ray
    Quote Originally Posted by Cobra Ray View Post
    Ray
    Ford added the CMCV function to the Gen 2 Coyotes starting in 2015. Your Gen 1 2014 Coyote doesn't have it. Therefore no vacuum motors on the back of the intake.
  10. #9
    Dracut, MA
    Thanks!
    Ray
