Thread: Panel adhesive
    Dec 2018
    Panel adhesive
    It's time to start mounting aluminum panels. I would be very interested to hear what panel adhesive other people are using for this application
    Thank you
    wallace18's Avatar
    Trenton, Florida
    Black GE silicone II.
    Southport, NC
    I've been very pleased with the Permatex products.
    Black Silicone Adhesive Sealant for most of the panels. Ultra Black in areas close to the exhaust system.
    George
    Sep 2015
    Beachside
    I just used the regular GE silicone. Gave both surfaces a solvent wipe first.
    FFR #8833 289 FIA 3-link
    GE Silicone II.
    May 2016
    would this be the same adhesive you all would use to glue in the louvers above the exhaust?
    Mar 2013
    Medway, MA
    I recommend this Bostik Polyurethane adhesive:
    https://www.breezeautomotive.com/?s=...t_type=product
