Power steer set up problems.
Hi Everybody,
I'm sure I can't be the only one who has faced this problem.
I have a blueprint 306 engine with installed power steering pump.
The rack and hoses came from factory five.
The rack was a pain to get to sit in the chassis but I managed.
Fitting the hoses is a whole different ball game. Without instructions I assume that the two ports on the pump and rack with the red plugs had to be plumbed to each other. Difficult to arrange the line but got it situated. How ever I have tightened the nuts as far as I can but the tubing still is loose and rotates. I am sure that this will leak as soon as the pump spins up.
The return line between the nipple on the pump and blue fitting on the rack will not fit no matter how I position it as it is interfered with by the other fittings or the chassis member
2019-02-17 14.24.23.jpg2019-02-17 14.23.48.jpg2019-02-17 14.23.44.jpg2019-02-17 14.23.39.jpg
Do I need to contact Factory five or just source better parts from an auto store.
Keith
