Have my Willwood brakes installed and moved on to bleed them using the standard two person procedure. Could not get the fluid to move after multiple pumps, holds, open/ closes. The level in the resevoire did change. Any suggestions?
Also I noticed there are 4 nipple valves per caliper....what's up with that? My past experience with brake bleed only had one nipple for each caliper.
