0
Radiator leak
I’ve got a gen 1 coupe, with the aluminum Afco rad. It developed a really mild leak somewhere on the passenger side a couple of years after I got it on the road. Over time, that leak got a bit worse, so I had the rad inspected at a local shop, but all they could do was try to epoxy it. That worked for a while, but now it is leaking again, a bit worse.
I seem to remember reading somewhere that this is a pretty common problem with these Afco rads, so I am reluctant to just replace it with another one. Does anybody know of another rad type that would fit into the same spot, even if it’s not aluminum?
