Results 1 to 4 of 4
Thread: Radiator leak
Hybrid View
    Radiator leak
    I’ve got a gen 1 coupe, with the aluminum Afco rad. It developed a really mild leak somewhere on the passenger side a couple of years after I got it on the road. Over time, that leak got a bit worse, so I had the rad inspected at a local shop, but all they could do was try to epoxy it. That worked for a while, but now it is leaking again, a bit worse.
    I seem to remember reading somewhere that this is a pretty common problem with these Afco rads, so I am reluctant to just replace it with another one. Does anybody know of another rad type that would fit into the same spot, even if it’s not aluminum?
    https://www.summitracing.com/search/.../summit-racing
    I've had good luck with one of these in Mk4 for several years.
    Not sure what size you need for the coupe.
    I did take mine to an aluminum radiator shop and get it modified a couple of times (pretty cheap to modify).
    Most important - make sure you have a good ground from the engine to the battery - otherwise you set up galvanic corrosion when amperage from the starter makes it's way through the antifreeze + radiator to the frame / battery - this will make pinholes quick.
    A sacrificial anode is a good idea in aluminum radiators too: https://www.summitracing.com/search/...&keyword=anode
    Thanks Mike. I’ll need to measure mine and see if there is one of those that is a good fit. I’ve heard the Coupe rad is from some production vehicle, but upside-down... but not sure what that vehicle is.
    Since the rad is on a slant and I’ve already got a filler cap / overflow fitting in-line in the upper hose, I’ll see if I can find one of those rads without a cap opening. Now that I think about it, that cap would just get in the way of the tie-down bracket anyway.
    Thanks for the tip on the galvanic corrosion- I didn’t know about that. I think my engine-to-chassis ground is pretty good, but I’ll check it again, and can’t hurt to install one of those anodes anyway.
    Thanks.
    Quote Originally Posted by JohnPR View Post
    The two mods I had the radiator shop do on mine were eliminate the cap opening + add a bung for the anode (put it in a good place to drain radiator).
    I think I paid them $50 - I think the radiator was $159, but I think I caught it on sale.
    P.S. It's also handy to have a bung in the top of the radiator to get air out - that's what I did in place of the radiator cap fitting - but that's not a good place for the anode (if there's any air, and there will be).
  5. Thanks JohnPR thanked for this post
