Thread: Wipers
    Burlington, WI
    Wipers
    I know this horse is dead, but I thought I'd kick it one more time. I am using the FFR wipers and the wheel houses supplied and having an issue with securing the wipers to the wheel houses. The splines don't really connect anymore and I tried to remedy the situation by drilling and tapping a whole in the wiper to tighten against the wheel house. Not a good mod for me.
    I have seen, but can't seem to find, better mods for securing the wipers.
    Any suggestions would be appreciated.
    Jay
    Road Legal August 31, 2017
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Jay -
    I had to "massage" mine quite a bit to get them to engage properly, but many in the past would replace the FFR supplied wheelhouses with aftermarket versions from **********. Not sure if that's still the best answer, so maybe someone who has modded theirs recently can help.
    Later,
    Mk3.1 #7074
    Burlington, WI
    Chris,
    Now that you mentioned it, that was an option. I am hoping to salvage mine. Pinching pennies.
    Jay
    Copperhill, TN
    I drilled and tapped the arms on two sides then used two cut down 10-32 stainless button head screws as set screws, look like they belong there...
    I found this that shows the set screws, you can see them on the wiper arms
    Southport, NC
    Try to find a SS collar or make one out of aluminum that will fit over the wiper arms housing with a set screw that will go through that housing onto the knurled part of the wheelhouse.
    George
    Jay - just another thought. When testing, make sure that you are putting paper towels under the wiper blades to mimic the reduced friction of a wet windscreen. Dry, the blades will have much more resistance to moving and the wheelhouses will tend to slip.
    Later,
    Mk3.1 #7074
    Burlington, WI
    Wiper problem solved thanks to all your input. I decided to drill and tap 10 32 holes and insert button screws. We all have a rather good supply so they're always available. And Chris, I have wrapped the blades in plastic cellophane for good measure. I always get a satisfying feeling when things work well.
    Jay
  8. Likes John4337 liked this post
