Administrator
4 link full droop driveshaft hitting frame
I am building a Hot Rod for a customer with the 4 link suspension. The longer shocks are in the rear per the instructions and I have the suspension points on the lower holes. I cannot connect the driveshaft without lifting the rear end while at full droop because it hits the frame at the driveshaft safety loop on a Gen II Hot Rod. There are no limit straps. Anyone else run into this issue and if so, how did you fix it? I have a set of Roadster limit straps that I was thinking of making a bracket and using them.
Thx,
Henry
