Results 1 to 10 of 10
Thread: 4 link full droop driveshaft hitting frame
    Port Charlotte, FL
    I am building a Hot Rod for a customer with the 4 link suspension. The longer shocks are in the rear per the instructions and I have the suspension points on the lower holes. I cannot connect the driveshaft without lifting the rear end while at full droop because it hits the frame at the driveshaft safety loop on a Gen II Hot Rod. There are no limit straps. Anyone else run into this issue and if so, how did you fix it? I have a set of Roadster limit straps that I was thinking of making a bracket and using them.
    Thx,
    Henry
    Santa Clarita, CA.
    Do you have your pinion angle set yet?
    Pictures?
    Port Charlotte, FL
    I guess I am not sure how to set pinion angle on a 4 link? The upper and lower control arms are fixed length. If I am
    Missing something, please let me know?
    Thx,
    Henry
    Santa Clarita, CA.
    Adjustable Uppers but only if needed.
    https://www.spohn.net/shop/Factory-F...ot-Joints.html
    Quote Originally Posted by 65 Cobra Dude View Post
    Thx,
    Henry
    Port Charlotte, FL
    Thanks for the link. I know there’s not a lot of 4 links out there but I’m guessing others have run into this issue as well and maybe there is another solution other than buying new uppers. Anyone use limit straps?
    Thx,
    Henry
    Stillwater, NY
    Are all the control arm bolts tight? When you torque all the bolts, it will take the slack out of the 4 link and uppers will straighten out and roll the axle back so the pinion will turn up. Other than that, yea, there's no adjustment on the 4 link other than the lower mounts on the axle.
    Arrowhead's '33 Hot Rod Build Site:
    http://sites.google.com/site/arrowheadshotrodsite/Home
    Do you have the correct transmission mount and spacing. I had to space my trans mount up a little to get everything to work
    Port Charlotte, FL
    DS,
    I am using the stock FFR tranny mount. Are you saying your driveshaft does not hit the frame at full droop? Looks like the tranny would need quite the shim. Everything is tight and I ended up using pickup truck tail gate straps as knit straps for now.
    Thx,
    Henry
    Henry
    I used tailgate cables for limits on my 4 link. I ran them from the torque boxes to the chassis tubes so they were as far outboard
    as possible. If they were closer to the middle and only one side was at full droop it would allow the other tire to contact the fender.
    HTH
    Dale
    Bourne-Cape Cod, MA
    nevermind
    FFinisher/AKA RE63
