0
0
LCA mounting point too narrow
I'm test-fitting the LCA bearings in their mounting points tonight. Three of the four bearings fit with extra room to spare (as expected) but the driver's side front mounting point is narrower than the other three by a full 0.2" according to my calipers, and the bearing will not fit in the mount at all. Now, I've read that it's not uncommon for the mounts to sometimes be too narrow and require spreading, but this seems like a pretty big discrepancy on this one mount. So if I try to spread it, I'm assuming I don't need to spread it as far as the others... just enough to get the bearing in, correct? Would it OK to install three of the four with washers to take up the extra space, and this one without?
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
