Thanks Thanks:  13
Likes Likes:  4
Results 1 to 34 of 34
Thread: FE style surge tank for 302 ?
    Member CNIdog's Avatar
    Does anyone have a source for a FE style surge tank that would fit a 302?
    Hope This Link Helps:
    http://dovemanufacturing.com/water_tanks.html
    Good Luck From The Dark-Dart Side!
  3. Thanks CNIdog thanked for this post
    May 2016
    I know this doesn't directly answer the question but you don't need one. A recirculating cap and a overflow can will allow for system expansion. I have been driving my car this winter in texas and has not required additional coolant and hasn't been hotter than 180 degrees according to the gauges. Good luck with your build.
  5. Thanks CNIdog thanked for this post
  6. #4
    May 2016
    Nice find. That is cool looking.
  7. #5
    I just like the style. The problem is FE outlet bolts are 90 degrees off the pattern of the 302 which makes the FE part incompatible without mods that are beyond my skill-set... I'll probably stay with the in-line filler. Unless someone has a mirror image of the FE tank.
    This pic shows the right side exit but the flange is 90 degrees off:
  8. #6
    Oct 2014
    Vermilion, OH
    I found this a while back on the other forum.
    http://www.ffcars.com/forums/160-mod...all-block.html
    CVOBill
  9. Thanks CNIdog thanked for this post
  10. #7
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    you also need to have the water return line that connects from the water pump out to the block. So the FE will only work if you're into cut and weld.
    BUT I did find one company that was making the old Ford Galaxie FE engine expansion tank into a small block expansion tank.
    http://classicfordradiator.com/63-66...sion-tank.aspx
    I have not purchased one from them but so far they are the only company that I have found that offers one without having to do the cut up of parts to "make it fit".
    There is also a company called Campion Cooling - a Matt Dawson - that is considering creating one for a small block.
    They have already done a FE engine one - not like the original Galaxie tanks all aluminum.
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
  11. Thanks CNIdog thanked for this post
  12. #8
    Here is another option;
    https://vintagewheelsus.com/index.ph...products_id=52
    Just google fe expansion tank
  13. Thanks CNIdog thanked for this post
  14. #9
    Grand Rapids, MI
    FYI: Superformance supplies a tank with their SBF installs, it's much like the Vintage unit previously mentioned. It was available in stainless or black paint. Kirkham has or had one, a friend bought one, expensive but very cool machined aluminum. In many ways the tanks are a PITA, often multiple gaskets, twisted hoses and it always seemed to be in the way. But then, nice to work with once installed properly.
    I have a fab'd aluminum unit from Olthoff Racing that I'll rework to form better, i.e. less complex, connections but I'm also looking at off-engine mounted alternates. I do kinda like this one though, it's sand blasted, coated with high temp clear over dirty fingerprints, suits me well.
    Jim
  15. Thanks CNIdog thanked for this post
  16. #10
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Quote Originally Posted by CVOBill View Post
    Hi - that how-to from ffcars.com is me and the same info is on this forum. Happy to help out with any tips, as I used an original Ford big block tank with a few no-weld mods to adapt it to my small block. PM me if I can help.
    Later,
    Mk3.1 #7074
  17. Thanks CNIdog, CVOBill thanked for this post
    Likes CVOBill liked this post
  18. #11
    Oh, I forgot my tank, thanks Chris, I copied what you did.
  19. Thanks CNIdog thanked for this post
  20. #12
    Pics of mine in both big block and small block dress. The big block look was accomplished with adapters for the valve covers.
    Later,
    Mk3.1 #7074
  21. #13
    Found this. A lot more than I would pay. sigh.
    This one is a bit more inline price wise:
  22. #14
    Dang! Mine was something like 35 bucks on ebay..... but that was 10 years ago, I guess
    Later,
    Mk3.1 #7074
  23. #15
    Yep, bought mine at a swap meet for about $40. I still have 2 that could still be converted and used.
  24. #16
    Any chance of selling one? :-)
  25. #17
    I really don't think I'll need them. I'll dig them up and post a picture
  26. Thanks CNIdog thanked for this post
  27. #18
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    I've ordered one of these and should have it by early next week
    He is installing a place for me to thread in my fan thermo switch that I currently have installed in my thermostat housing.
    We'll see how it fits on the 5.0L engines.
    Ralph Button
  28. Thanks CNIdog thanked for this post
    Likes CNIdog liked this post
  29. #19
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    I took an old FE surge tank and had a bracket cut, then modified the tank and welded the tank to the bracket. Still have an extra tank and bracket!3C4E58E2-5F52-4DD9-AE17-E91B029F7074.jpeg935F4412-5D46-459F-9ED1-4B0B98EDBB5E.jpg
  30. Thanks CNIdog thanked for this post
  31. #20
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    Here is what they built for me as a FE style surge tank but to be used on a 5.0L engine
    All nicely done BUT for me I'll need to move my alternator lower on the passenger side of the motor.
    I have power steering on the driver side of the motor so to "balance out" the engine I placed the alternator on the passenger side - also so I could use a serpentine belt not a V belt.
    They also put in place a threaded hole in the bottom of the tank for the electric fan switch.
    So I can't install it yet till I get some brackets to move my alternator lower.
    Ralph Button
  32. Thanks CNIdog thanked for this post
  33. #21
    Looks great! Just what I'm hoping to get. How much did it cost?
  34. #22
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    sent you a PM
    Ralph Button
  35. #23
    Santa Clarita, CA.
    Here is mine with and without expansion tank. Tank from Superformance. Stupid expensive.
  36. #24
    Kirkland, WA
    Quote Originally Posted by R. Button View Post
    Looks good, so no support brackets except to bolt to manifold thermostat housing?
    I went with for mounting alternator low
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  37. #25
    Thats the same alternator bracket I used.
  38. #26
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    just the two bolts through the thermostat housing!
    Ralph Button
  39. #27
    Summerfield, NC
    I have the speed dr low alternator mount on my car. It's a great piece, but it is a PITA to go under the car to tighten the belt if you need to.
    Ralph...have you mounted the tank in the car with the distributor in place? I had that tank back when ********** was selling them. Manufactured by the same people you bought it from. It wouldn't fit with the larger size EFI distributor in my car and I couldn't find a small cap version of the efi distributor available, so I returned it. I wound up modifying an original tank (and then had to replace it after a while with another modified tank because the seam split on the first one).
    But it'd definitely a cool look.
  40. #28
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    With the dual carbs I had to go with a small diameter distributor. Took some searching but I found a 1976 Bronco 5.0L distributor that was wired for a duraspark ignition system which is what I'm using. It took a lot of searching but found the information on a Bronco forum! Seems a lot of the people rebuilding 1985 mustangs are also using this distributor for the spark advance. Once I found the right distributor wouldn't ya know amazon would carry it! I also have a Pertronix small cap distributor that if needed I was going to rewire for. So yes I noticed that the large cap EFI distributors were going to also have issues with the surge tank! Good point to bring up for others considering it.
    Ralph Button
  41. #29
    Burlington, WI
    Quote Originally Posted by Gumball View Post
    I thought that looked like your engine bay. Very nice. From the beginning of this thread I thought one should look at Chris' work. Sure enough it was yours. Makes me want to do another cobra.
    Jay
    Road Legal August 31, 2017
  42. #30
    Kirkland, WA
    Here is my first mock-up and fit, not sure if it will go black or gold. Have to finish the hose fit as NAPA hose was not quite a fit
    Tony Nadalin
  43. #31
    Orlando Fl
    Any news on this for 2023?
    I am looking to put one of these on my new 347 stroked that is a ford sb 302.
    Anyone now making one? No luck searching…
  44. #32
    Jan 2022
    Seven Hills, OH
    Got mine here: Classic Radiator 516-293-2175.
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  45. #33
    mburger's Avatar
    Punta Gorda FL
    I used Speed Doctors alternator bracket to lower my alternator. I had to make a spacer out of aluminum stock so the tank would clear the distributor.
    Mark
  46. #34
    Orlando Fl
    Thanks, I will call them tomorrow.
