Thread: Hot Rod Truck without Fenders Legal in PA?
    Feb 2019
    I'm wondering if the Hot Rod Truck can be built without fenders and be legal in PA? Any one know?
    Seasoned Citizen NAZ's Avatar
    Don't know about PA but would caution you to look for mud flap rules in your vehicle code. That's the way some states get you for being fenderless.
    Feb 2019
    Thanks.
    Really like the look of the truck without the fenders.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    From the PA Motor Vehicle Code (https://codes.findlaw.com)
    Pennsylvania Statutes Title 75 Pa.C.S.A. Vehicles § 4702. Requirement for periodic inspection of vehicles
    (c) Safety inspection criteria for street rods.--The department, after consultation with the National Street Rod Association and other interested groups, shall prescribe special inspection criteria for vehicles registered as street rods.  Vehicles registered as street rods will not be required to be equipped with bumpers, fenders or engine coverage as originally manufactured.  If the hood, top and sides, or both, are removed from the vehicle, the engine fan must be enclosed with a shroud designed to protect the fan from accidental contact from the outside.
    Ray
    Feb 2019
    I'm liking that. Thanks.
    Dec 2018
    yes
    Super Moderator
    Ray's Avatar
    La Mesa, California
