The turn signal light housing touches in the middle before the rubber gasket can touch the body.
Should I clearance the center hole in the body so the gasket acts like a gasket end touches the body and the housing.
Second,I saw a picture in the directions that looked like the bracket that came attached to one screw at the front turn signal position and the other end was on the bumper bolts wasn’t installed. I am assuming that it must be installed. Also the holes that were factory drilled for the front turn signal light housing are about 1/16 inch to close together. I just elongated the bottom hole.
