Thanks Thanks:  4
Thread: Broken Brake Switch
    Senior Member Jethrow's Avatar
    Perth, Australia
    Broken Brake Switch
    Hi everyone.
    So I do not know how or why, but as part of the painting process i am going thru on my car, I noticed the brake switch had broken.
    The plastic threaded section had snapped of from the main switch body.
    So i need to purchase a replacement but it seems F5R do not list this item in the parts catalogue. Anyone know where I might source one?
    Thanks muchly.
    Tim
    FFR MkIV #7393 - LS3, TR6060, 8.8" - Registered 2015 - Painted 2019
    HSV Clubsport R8
    Kwaka ZX-14R
    Santa Clarita, CA.
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    O'Fallon, MO
    Common Ford part, should be available at an Auto parts store.
    Jun 2015
    Fairfax Station VA
    Try this: https://www.amazon.com/ACDelco-D885-.../dp/B0013FDN5A
    EDIT: Thanks to edwardb for providing the part number in a post long ago...
    MK IV Roadster #8631
  5. Thanks WIS89, edwardb thanked for this post
    Highly recommend the AC branded switch versus the generic one. FYI Factory Five is using a different style switch now. Mounts and wires the same but physically different. They don't have all their parts listed in their on-line catalog.
    Senior Member cobrajj's Avatar
    Murrieta, Ca
    When mine broke, I found one at PEP Boys. I brought in the old one and they matched it to a mid 70's Chevelle. Pretty generic part.
    Mk3.1 Complete kit #6846 Delv. 12/20/08-- Finished 2/11/11, 89 302 EFI,T-5, 3-Link, 17" Halibrands, Nitto 555 245-315 tires, widened drivers footbox w/ dead pedal, extended passengers footbox,Sapphire Blue Met & Wimbledon White stripes,radiator stone guard shield, Build blog http://jimsffrcobrabuild.blogspot.com/
    Thanks for the number John. When mine died I went to AZ and found one that might work out. Then to Advance and they had the exact match. But, as usual, it's no fun going there and they ask for make, model, and year and I say I have no idea. One time the guy even tried and entered Shelby but no match.
    Perth, Australia
    Thanks everyone. I went to my local autoparts store (called Supercheap Auto in Australia) and found a switch made by Tridon - TBS072. Seems to be an exact copy for this generic item.
    Thanks for all the tips.
    Tim
    HSV Clubsport R8
    Kwaka ZX-14R
  10. #9
    Jun 2015
    Fairfax Station VA
    I should have credited edwardb in the original post for providing the part number in a post long ago...now fixed.
  11. Thanks WIS89, edwardb thanked for this post
