I’ve just installed the panhard bar. On page 80 of the Assembly Manual it says,
“To set the pinion angle, make sure that your ride height is where you want it, and then adjust the upper arm until the desired angle is reached. We usually run about 2 degrees up on the rear axle, but you can adjust this to fit your particular set-up.”
What is the ride height, and how do you set it, and how do you know where to set it?
