Likes Likes:  3
Results 1 to 40 of 46
Thread: Parts for power brakes
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Hi all, i'm wanting to change to power brakes and was wondering if anybody had figured out the parts, over the counter for a setup like Whitby offers?
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Lilburn, GA
    Question, what foot pedals are you using, Wilwood or mustang? Because I have a Wilwood pedalbox, I had to make my own brake pedal, post 194. Whitby also sells one.
    Check out the link below.
    https://thefactoryfiveforum.com/show...l=1#post293305
    Tybee Island, GA
    I have a sn95 pedal box, with '93 brake booster (whitby) and a '95 Mercury Villager MC (abs or non abs - your choice) that needed to have a bit of machining (similar to what whitby does). I enlarged the mount holes on the MC to 7/16" and increased the depth of the MC plunger to 1.00" from 0.875 with a 7/16" bit. If you go with the abs MC, you'll need to do a little bit of adaption to get to the inverted flare brake lines of your car. I used 2 spacers inbetween the MC and the booster.
    You'll also need to move the steering flange bearing to the inside of the Footbox,
    Untitled by D. R., on Flickr
    trim the the 3/4" frame tube so that the booster will have room to fit,
    IMG_1983 by D. R., on Flickr
    and will also need to enlarge the hole where the booster will enter the footbox. To mate the booster up to the footbox wall, you'll need a spacer in between the booster and the front wall. ReplicaParts.com does a spacer that fits and seals the gap well.
    And finally, if you have a sn95 pedal box, you may need to do a little knotching on the pedal box to get everything to fit (because you moved the flange bearing to the inside of the box).
    Hope this Helps!
    More Pics
    Whitby also includes the reservoirs, bracket, hose and nipples that fit in the MC.
    Videos are at: YouTube Videos
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    I already had the MC and remote reservoirs for my manual setup so didn't need the full Whitby setup. I bought a 93 booster (https://www.summitracing.com/parts/aaz-54-73207) and already had a 95 Cobra MC from Breeze. Everything bolted right together, didn't need to machine anything (except for cut a 2.5" hole in the firewall with a hole saw - use a wood template bolted on) and also created 3/8'' spacer between the booster and firewall. For the gap in the frame, I cut the frame at about 1" and 7" and bolted an 8" long piece of square tube on the outside (credit goes to Mike Everson's threads for that idea).
    As a caveat, I have yet to drive it so can't attest to how well it all works. I have GT brakes all around so all the parts should match.
    Booster
    For you guys retrofitting from manual to power be aware that if you modified the pivot of your pedal (as you should have if you used a donor pedal box from a car originally equipped with power) you will need to go back to the original configuration. If you use the manual pivot geometry with a power booster your brakes will be ultra sensitive and act kind of like an on/off switch!
    FF6602's Avatar
    Nov 2018
    State College, PA
    Hey Jeff,
    This is the first time I've heard about moving the pivot point when using a donor footbox w/ manual brakes. Where can I find the info on that modification? Thanks!
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
    Got a manual? It'll be in the donor parts prep section.
    Dec 2013
    Navasota, Texas
    Yes i did cut down my brake pedal and am in the process of trying to find a replacement. But thanks for the reminder Jeff.
    Anybody needing one already cut down i will trade you and pay shipping, will need to be for 1987 to 1993 mustang with manual tranny!
    Walt
    FF6602's Avatar
    Nov 2018
    State College, PA
    Thanks Jeff! I found it in the manual (page 28-29). Now I'll have to go check the car to see if this has been done. As always, I appreciate the heads-up!!
    Craig
    FF6602's Avatar
    Nov 2018
    State College, PA
    Quote Originally Posted by Walt View Post
    Walt
    Walt, I may be just the guy you're looking for. I bought 6602 as an unfinished kit and the pedals are already installed. I'll check them this weekend to see if the brake pedal has been modified. If not, I'd be happy to swap with you. Please stay tuned!
    Craig
    FF6602's Avatar
    Nov 2018
    State College, PA
    Does this brake pedal mod look right??
    I checked out my car yesterday, looking for the brake pedal mod described in the Mk3 build manual and mentioned in Jeff's post. Here's what I found:
    1.) The pivot arm has been moved to the lower set of holes referred to in the build manual.
    2.) I see no sign that the pedal arm was modified by removing 1.5" between the pivot and the pushrod attachment point, as the build manual instructs.
    3.) What I did find was what appears to be a "custom" pushrod extension, that was welded to the master cylinder pushrod. The extension looks like the letter "P" laying on it's side with the loop pointing down towards the floor. Like this crude drawing:
    Does this look like it would work for the proper leverage on a manual braking system....?? Or, should I scrap the "custom" pushrod and...
    A.) Follow the build manual instructions about cutting and sectioning the pedal, then replace the m/c pushrod?
    OR
    B.) Switch to aftermarket pedals (i.e. Wilwood or Maximum Motorsports Pedals)? Is there a Forum Sponsor that makes/sells such parts?
    Craig
    Dec 2013
    Navasota, Texas
    Craig ,If the brake pedal pad is at the same height from the floor it has been cut down, im out of town for a couple of days, when i get back i will measure the length to compare to yours.
    Walt
    That should be same as the clutch!
    Craig,
    What you have there is an adjustable pushrod. It allows you to change it's length to adjust the pedal height but does not change the geometry of the pedal.
    Norton, MA USA earth
    That pedal has bee modified. In fact it was done by me. I don't cut and reweld the pedal. I cut off the pivot on the top and drill a new pivot hole then weld in a new pivot tube.
    Your pushrod is a stock modified unit.
  15. Thanks FF6602 thanked for this post
    Likes FF6602 liked this post
  16. #15
    FF6602's Avatar
    Nov 2018
    State College, PA
    Walt
    Thanks for the offer Walt. However, based on Mike Everson's reply, it appears unnecessary because he confirmed that the pedal was modified by him! So, I think I'm good to go!
    Craig
  17. #16
    FF6602's Avatar
    Nov 2018
    State College, PA
    Wow! That's great news, Mike! Makes me feel so much better about the braking system -- I'm so glad that you took time to read my post and look at the photos. I wonder if there is anything else on the car that has your name on it? I've visited your website and would be proud to have any of your parts on my car! FYI -- The 6602 Mk3.1 kit was sold in 2008 to a Ronald Brown in Wakefield, RI if that rings a bell. He did the majority of the work to get it to the go-kart stage before selling it to Dave Butler in Deep River, CT in 2017.
    Again, thanks for time and interest in my car and everyone else's on this forum! I love the cooperative camaraderie!
    Craig
  18. #17
    FF6602's Avatar
    Nov 2018
    State College, PA
    Craig,
    Thanks Jeff. I learned lots of good news since yesterday's post from you, Mike and Walt. Much appreciated!
    Craig
  19. #18
    Dec 2013
    Navasota, Texas
    So on the Whitby set up with a fox pedal setup is it plug and play?
    Walt
  20. #19
    Tybee Island, GA
    Walt
    See below: Even with Fox pedal assy, I expect it will be similar process to install. Not exactly plug and play.
    Quote Originally Posted by DadofThree View Post
    Hope this Helps!
    More Pics
  21. #20
    Craig. Post some pics of the overall car. Lots of us old timers can tell you a lot based on pics.
  22. #21
    Dec 2013
    Navasota, Texas
    Dave, does the whitby setup come with the spacer?
    Walt
  23. #22
    Tybee Island, GA
    Walt
    I believe that it did (MC spacers and small spacers for the booster). The spacer from replicaparts.com did not come with the kit. The power brake kit was a complete kit that had a lot of parts and thought put into it.
  24. #23
    Dec 2013
    Navasota, Texas
    So it looks like even with the spacer the bearing would need to be moved inside, is that right?
    Walt
  25. #24
    Tybee Island, GA
    Walt
    Yes. Don't pay attention to the title of the blog posts I'm attaching. The frustration was fresh in my head. But you have the advantage of doing this after someone else's frustration of figuring it out.
    Day 1 of install
    Day 2 of install
  26. #25
    Dec 2013
    Navasota, Texas
    Ok, thanks Dave, i talked to Jeff at Whitbys this morning he said the kit should ship next week, heres hopeing! I ordered the spacer and it should also ship next week.
    Walt
  27. #26
    Dec 2013
    Navasota, Texas
    Cfranks, where did you get the remote part ?
    Walt
  28. #27
    Dec 2013
    Navasota, Texas
    Hope this Helps!
    More Pics
    Dave, how did you increase the MC with a drill bit?
    Walt
  29. #28
    Syracuse, NY
    This is how I did my pedal too. The thought of cutting a brake pedal in half, then butt welding it with a mig welder, sounds like a recipe for disaster to me. Just imagine the weld failed during a panick stop.
  30. #29
    Dec 2013
    Navasota, Texas
    Well i have been waiting for the whitby brack kit for over 6 weeks now, it was supposed to be 2 weeks! I'm thinking about going over the counter, anybody know what booster and master fits best without machine work?
    Walt
  31. #30
    Dec 2013
    Navasota, Texas
    Quote Originally Posted by CFranks View Post
    Booster
    Cfranks, did you get the parts that go in the MC from Breeze, that fits the hoses to remote resevoirs?
    Walt
  32. #31
    Mar 2018
    Berwyn, PA
    Walt
    Hi. I got them from Lodestone Billetworks - http://www.lsbilletworks.com
  33. #32
    Dec 2013
    Navasota, Texas
    Ok, thanks
  34. #33
    Dec 2013
    Navasota, Texas
    CFranks, did you need to move the steering bearing to inside the footbox with your booster?
    Sorry to bug again!
    Walt
  35. #34
    Mar 2018
    Berwyn, PA
    Yep, had to move it inside the footbox as do most people. I also had made a 3/8” spacer to go between the booster and footbox to locate the pedal properly, but even with that still needed to move the bearing. Was kind of a pain for me since the car was fairly far along, had to loosen the steering rack to get enough play to pull out the steering shaft. Few free to PM if you want to talk on detail what I learned.
  36. #35
    Dec 2013
    Navasota, Texas
    Thanks, i have the e-steering and taking it apart is a pain, but am trying to get all the parts i think ill need.
    Walt
  37. #36
    Dec 2013
    Navasota, Texas
    Cfranks, i got the inserts for the master, where did you get the clips to hold them in?
    Walt
  38. #37
    Mar 2018
    Berwyn, PA
    Walt
    Hi. They're just press fit in and not supposed to require clamps since it's not the high pressure side of things. Mine do have zip ties holding them on, not sure if they're necessary but make you feel good.
    MK IV Roadster #7999
    Ford Racing 427x; QF 670 Carb; TKO 600; 3.31 Rear End; 3-link; 17” Halibrand Replicas (9” front, 10.5” rear), Khumo Ecstas (245 front, 315 rear), EPAS Power Steering; Power Brakes; 8/1/19 - Legal in gelcoat!; 12/1/20 - Paint & bodywork in progress! Silver, no black, no red, wait now silver....
  39. Likes toadster liked this post
  40. #38
    Dec 2013
    Navasota, Texas
    Power brakes
    Booster
    CFranks, did you have to move the inner fender liner forward to make room for the larger master cylinder?
  41. #39
    Not CFranks (...) but I'll respond since I installed one of those too. Not really practical to move the splash guard. Common solution is to cut a clearance hole. Only sticks through an inch or less. Then attach some kind of cover to the splash guard if you prefer. Ask Jeff Kleiner about the official dog bowl mod. Another of his innovations.
  42. #40
    Mar 2018
    Berwyn, PA
    Hi, I did exactly what EdwardB said. Drilled about a 2.5 inch hole in the splash panel and used Kleiner’s “Fluffy’s Bowl” mod. (Rivet a little cat bowl to cover up the opposite side of the hole)
