25th Anniversary #9772
I have the wilwood pedalbox and fitted up the Whitby power brake setup...
https://cobradreams.com/2020/05/18/c...-power-brakes/
definitely requires some tweaking and patience!
I highly recommend the spacer from replicaparts as well since it will seal up the footbox and give the needed space!
http://www.replicaparts.com/BRAKE%20...CER%20PAGE.htm
plus it's a great template to drill your holes!
Great to hear , i already drilled the hole, i have the plastic liners so can try to find something like that to go there.
Thanks guys!
Walt
FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
Originally Posted by
CFranks
Hi, I did exactly what EdwardB said. Drilled about a 2.5 inch hole in the splash panel and used Kleiner’s “Fluffy’s Bowl” mod. (Rivet a little cat bowl to cover up the opposite side of the hole)
Dog bowl... cat bowl... knew it was one of those. Shopping the car parts aisle at your local PetSmart.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Not a waxer
That looks great, how did you guys mount your reservoirs and where, im having to mount 2 singles for the brake master.
Well finally got the brakes changed to the power set up i came up with , they work awsome.
Thanks to you guys that helped with finding parts!
