AC Compressor Line Bolt
Hey guys,
I’m looking for the bolt that secures the AC lines to the back of the compressor. The GM PN is 15726460, but it is discontinued. I think a replacement number is 14056165.
Can anyone confirm this or point me in the right direction for this bolt?
Sean
Hi Sean,
I know it's a pretty standard sized/threaded metric bolt. I normally just scrounge thru my spare/donor bolts bin until I find one that works. Besides....I'm not sure if the Vintage Air AC manifold is the same thickness as the GM manifold that bolts up there, so not even sure that the factory bolt is what you would need?
Shane Vacek
VRaptor SpeedWorks, LLC
www.vraptorspeedworks.com
Hi Sean,
Sounds easy enough. From looking around I think it’s a 11mm x 1.5 so I’ll give that a shot.
