Thread: Forte Engine Mount Mod - Dart Block
    Senior Member cv2065's Avatar
    Dec 2017
    Hey guys. Just got my engine mounts back from Forte, and he's modified them for the Dart block. As you can see, he's not only notched them out to fit the block, but also took some iron angle and welded back in the support from the other side.
    Thought I'd share as there aren't too many pics of modifications around.
    Mar 2017
    Lafayette, CA
    Can you please point out the part that is notched? This is in our near future and although I’ve read a lot about this, I don’t know how much or where to notch.
    Thanks!
    MK4 Roadster #9138
    Blueprint 427 with Sniper EFI, TKO600, IRS, complete kit
    https://thefactoryfiveforum.com/show...8-Build-Thread
    Dec 2017
    Quote Originally Posted by dncharo View Post
    Thanks!
    The middle picture compares an original mount on the left with the notched mount on the right. Hope that helps.
    BadAsp427's Avatar
    Greeneville, TN
    Dec 2017
    Cool
    Show off!
    Mar 2017
    Lafayette, CA
    Perfect, thank you!
    MK4 Roadster #9138
    BadAsp427's Avatar
    Greeneville, TN
    Show off!
    Your Welcome!
    Senior Member broku518's Avatar
    Jupiter, FL
    Fancy! I encountered the same issue on my 347 dart block....ended up doing some fine surgery with my angle grinder
    (I didn't touched the block, only the metal mounts)
    Cape Coral, FL
    Quote Originally Posted by broku518 View Post
    I talked with Blue Print and they said I could go easy and take some off the block so I did both. Used touch up paint and the block looks untouched.
    Fits good now.
