0
0
Lower race in the transmission - 2WD conversion question
I am doing my 2WD conversion and have a question on removing "races". It is clear from Bob'n'Cincy and others that the small one up on the top should be removed while we're in there, and I've done that.
I have also seen here that "the lower race" should also be removed. I am not sure what that is.
Is it the piece the lower arrow in the picture below (I am unsure if this will come out or not), is it already out with the entire bearing on the center diff (upper arrow), is it something else, or should I not worry about it?
Cheers
- You may not post replies
- You may not edit your posts
Forum Rules
