0
0
LS3 bellhousing clearance
Hey all, to pass compliance testing here in Australia, the chassis needs to pass a 'torsion & beaming test' as Chris Canning had done here. As you can see in the link, a beam and gusseting has been welded in across the body at the firewall, level with the bottom of the chassis.
Can anyone with an LS3 fitted confirm the position of the bellhousing in relation to the bottom of the chassis? i.e. can I run an RHS as per the pic without hitting the bellhousing?
Chris is no longer in business and I can't tell from the pic what engine he's used. I know 'Barrel' has had this done but he's running a Coyote.
