Thread: Steering Wheel Problem
    Feb 2019
    I searched the posts for something similar to what my problem is but to no avail.
    People write about sloppiness, removable, etc.
    With my problem I cannot even get close to their problem.
    My wheel won't go on the shaft. Yes, I know the boss only fits a certain way and when it is lined up properly, it doesn't fit. I don't want to rubber mallet it on as that doesn't solve what I consider a problem.
    Anyone else have an install problem with the steering wheel?
    wallace18's Avatar
    Alachua, Florida
    Some times you have to sand down the shaft a bit. Or use steel wool on the shaft. Make sure there are no burrs on the hub inside. It is a very tight fit for sure. Good luck.
    Senior Member broku518's Avatar
    Jupiter, FL
    I had the same 'problem.'
    Didn't want to use a rubber hammer. Instead, I used some fine sandpaper and elbow grease. Worked magic!
    Senior Member ILPBFoot's Avatar
    Kildeer, IL
    Same here. It is a very tight fit like putting the spindles on. A bit of light sanding, a bit of lubrication and it will go on.
    You'll get it.
    Mk4 Roadster #9319, complete kit Received 4-10-18. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, w Holley 850 Double Pumper, manual Choke, 501 hp with 498 lb-ft torque. TKO 600 0.64 OD
    Feb 2019
    Thanks guys.
    It's coming along.PITA though.
    Quote Originally Posted by Dwleo View Post
    Thanks guys.
    Once its on, its a real pain to get off. Don't torque it down until you need to.
    MK IV #8901 - Complete kit, Coyote, TKO-600, IRS. Ordered 5/23/16, Delivered 7/14/16, First Start 8/13/17, First Go-Kart 10/22/17, Registered and Completed 10/18/18. Build Thread: http://thefactoryfiveforum.com/showt...V-Coyote-Build Graduation Thread: https://thefactoryfiveforum.com/show...-Roadster-8901
    Jax Beach, FL
    It's nothing a 6-pack a torch and a sledge hammer won't fix.
    Dec 2018
    I think the, only goes on one way, refers to the bolt pattern on the steering wheel and hub. Mine was tight as well. I used rubber mallet, but only tp tap it on. "Kit Car", it is.
    Senior Member Packer fan's Avatar
    Janesville, WI
    It sounds like your a fellow cheese head.
    Mk4 ordered 1/3/18, IRS, Coyote, T56 Magnum
Flat Irons Tuning
