Results 1 to 9 of 9
Thread: Steering Wheel Problem
    Feb 2019
    I searched the posts for something similar to what my problem is but to no avail.
    People write about sloppiness, removable, etc.
    With my problem I cannot even get close to their problem.
    My wheel won't go on the shaft. Yes, I know the boss only fits a certain way and when it is lined up properly, it doesn't fit. I don't want to rubber mallet it on as that doesn't solve what I consider a problem.
    Anyone else have an install problem with the steering wheel?
    Some times you have to sand down the shaft a bit. Or use steel wool on the shaft. Make sure there are no burrs on the hub inside. It is a very tight fit for sure. Good luck.
    Jupiter, FL
    I had the same 'problem.'
    Didn't want to use a rubber hammer. Instead, I used some fine sandpaper and elbow grease. Worked magic!
    Cape Coral, FL
    Same here. It is a very tight fit like putting the spindles on. A bit of light sanding, a bit of lubrication and it will go on.
    You'll get it.
    Feb 2019
    Thanks guys.
    It's coming along.PITA though.
    Quote Originally Posted by Dwleo View Post
    Thanks guys.
    Once its on, its a real pain to get off. Don't torque it down until you need to.
    Jax Beach, FL
    It's nothing a 6-pack a torch and a sledge hammer won't fix.
    Dec 2018
    I think the, only goes on one way, refers to the bolt pattern on the steering wheel and hub. Mine was tight as well. I used rubber mallet, but only tp tap it on. "Kit Car", it is.
    Janesville, WI
    It sounds like your a fellow cheese head.
