0
0
Dash Wiring loose ends
I did a post search and many were 4-5 years old with different gauge setups. Please help if you have the time. I have the autometer gauges and RF harness.
1. There is a red speed-clock-mem wire going near the speedo. The only pole I have left on the speedo is labeled "out". Does it go here?
2. I have a brown gage send wire by the speedo. I'm assuming this is another 12 volt feed, but I made the feed wire with the 4 7" and 2 12" red wires. I'm assuming the 2 12" went to feed the speedo and tach and hooked those in. Is this just an extra feed?
3. There are 2 speed sensor wires. 1 green and 1 grey. I plugged the green on into speedo. What is the grey one for?
4. There is a red speed-clock-mem wire going by the 5 gage cluster. I'm assuming this isn't used because I don't have a clock.
Thanks for the help
