Russ' Garage
Results 1 to 16 of 16
Thread: Cleaning out parts!
    The Traveler R. Button's Avatar
    Pittsburgh, PA/Elmira, NY
    Cleaning out parts!
    Over the years I seem to have collected boxes of parts!
    Here is a list of what I have for sale - offers accepted
    Electric fan - new $10.00 - SOLD
    water recovery tank - plastic (new) from Breeze & a black metal one Metal one $10.00 Plastic $8.00
    Willowwood 7/8 master cylinder with small plastic tank $10.00
    Pertronix Distributor w/separate coil $30.00 - SOLD
    MSD 8588 Distributor -SOLD
    No brand name distributor designed much like the Pertronix system w/separate coil $20.00
    Front grill from Breeze - For a Mark I - Mark III never installed it $10.00 - SOLD
    Used Autoweld rear adjustable lower control arms - for shipping cost - SOLD
    FFR rear lower control arms - for shipping costs - SOLD
    Disk brakes setup for Ford Thunderbird rears and Basic ford fronts w/rotors - power coated red. $20.00 would deliver if needed - depending on distance - SOLD
    A set of rear control arm bushings - 4 of them - for shipping costs
    cleaned up front disk brake calipers from a 1990 Mustang GT with spindles and just one rotor - $20.00
    headlights - one pair of blue dot centers and some tail lights $10.00 for the pair - SOLD
    A working HID set of head lights - worked great just as I travel a bit $15.00
    I went with the LED light bulbs in the headlights now. Easier to get parts while on the road! Often times I switch parts on my car to be sure I can get parts while traveling. That affect the choices I make for what parts to use. Also means I sometime collect piles of parts that I have pulled off my car - not because of a problem but solely based on available parts on the road!
    20190308_002141.jpg 20190308_004502.jpg 20190308_091030.jpg 20190308_091053.jpg 20190308_091131.jpg 20190308_091150.jpg
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    NY
    PM sent on distributor
    Senior Member HiggyMK4#9579's Avatar
    Southern Ontario
    PM sent
    Picked kit up on 4/3/19
    Build plan 351C, 3 link, 15's
    Feb 2018
    PM sent
    replied to each.
    I have three Distributors
    MSD 8598 - unused by me - it has a large cap so would not work with my dual carb system - SOLD
    Pertronix Flamethrower Ign II D130810 also unused by me - looks new with a new coil also
    TSP ready to run distributor with a spare small diameter cap and rotor also a one of TSP's coils
    https://www.topstreetperformance.com/products/ignition/distributors/ready-to-run-distributors/ready-to-run-ford-289-302-distributor.html
    I never installed any of them as I stumbled on a Ford Bronco distributor for a 5.0L small cap that works with my duraspark ignition module.
    As mentioned my criteria for parts is can I get a part quickly when on the road. So often pass up on performance for more of a stock part.
    These are the two distributors I have with the coils
    Ralph Button
    I also found that I have a spare unused ballast and wiring harness for the HID lights! So it comes with 3 ballast and a spare wiring harness with the relay. The HID's are BRIGHT! I recently switched over to LED light bulbs as they now sell the H4 LED bulbs to insert into a headlight housing which means on the road if I blew out a light I can just pickup a basic H4 bulb and plug it in. The HID I had wired to allow me to do the same - unplug the HID bulb and plug in a regular bulb bypassing the ballast.
    And by the way this is only one set of parts shelves. Am still cleaning up the other 2 shelves for the Traveler "Yard" Sale!
    Found on the second shelf a spare HID bulb too! So here is a pic of all the parts with the instruction book that I found too!
    Ralph Button
    The part I dislike... when I get multi people that want the same item... and I have to go by the time stamp when they say yes I want it.
    but it's my only choice to be fair
    Also keep in mind that these parts are for a Mark I and may or may not fit a Mark 4
    Like the grill is for a Mark 1-3
    Ralph Button
    Jun 2018
    Interested in the tail lights.
    two complete rear red ones.
    I you are interested in them
    Ralph Button
    Senior Member HookedonFord's Avatar
    Panhandle, FL
    Hi, I would like the "Used Autoweld rear adjustable lower control arms - for shipping cost" if they are still available.
    Thanks, Jim
    Jim, the autowelds are still avaiable.
    I sent you a message for address etc.
    Ralph Button
    Oct 2017
    PM sent on headlights and tail lights
    Scott, Lights are boxed up and will shipout tomorrow
    Ralph Button
    Jun 2018
    Pm sent on distributor.
    Feb 2018
    PM sent on grille - again.
    Jim
    jim,
    found a box and also sent the measurements of the grill
    Ralph Button
Flat Irons Tuning
