Results 1 to 6 of 6
Thread: Over Riders not fitting
    Tennessee
    Good afternoon all.
    So I bought some parts over the winter. It is finally nice enough to get in the garage and start working. I went to place on my new chrome overrider and, alas, it does not fit.
    Did anyone else have this problem? If so - where can I get the same bolt just a little smaller so the part will fit? I am a little irritated at Finish Line. I obviously can't return them since it has been about 5 months.
    Anyone else have this problem? How did you fix?
    Thanks in advance.
    Member Jim Doak's Avatar
    Midway, Utah
    I don't know if it's still the same as when I installed my over riders many years ago, but the four over rides were not the same; the front pair mounts were slightly different than the rear pair.
    Mk 1.5, 347 with Sniper EFI, T-5, 3-Link with VPM Rear Sway Bar, Power Steering with Hydraboost Brakes, Under Car Exhaust, SAI Mod, Rear Fender Flares, Dropped Trunk Mod, ... (Sold September 2019)
    Mark Dougherty's Avatar
    Hershey PA
    there are a few things you can do if you are handy / or have the tools.
    1) welder needed
    find the correct bolt that screws into overriders and weld them to the ends of the bolts you have.
    2) if you have a friend with a lathe have him turn and re thread the ends to your needs.
    3) all thread just purchase the correct size allthread to do the job
    The traveling Builder
    717-773-5624
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    I used the althread on mine with 2 nuts and worked great!
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Quote Originally Posted by Mark Dougherty View Post
    1) welder needed
    Option #4 put over-riders in the round file.
    Jul 2014
    colorado springs co.
    if they are the polished stainless steel you can drill them on a drill press, thats what i did, lot of work but go slow or it will burn polish job
