Thanks Thanks:  3
Likes Likes:  3
Results 1 to 17 of 17
Thread: Interior Door Opener
    Member clays123's Avatar
    I intend purchasing the ffr interior door release (comes with the coup) and retro fit to my 33 hotrod (roadster) for use instead of the hard to reach and operate one I have currently.
    Anyone done this so far? Will there be any issues in doing this?
    Any help is appreciated.
    I guess I am not familiar with what you are describing. I have tried both the pull handles, a custom lever, and finally had the originals installed with the pull cables.
    Jun 2018
    North Vancouver, BC, Canada
    Bourne-Cape Cod, MA
    Early hot rods had "normal" handles rather than the PIN used as of Late. Gen 2 hotrods also use the "normal" handles. I am sure if you call FFR they can set you up with handles and cables as well as any brackets you might need.
    The latches are all the same, also the same on the coupe so it should not be overly difficult to accomplish.
    FFinisher/AKA RE63
    Gatineau, Quebec, canada
    I simply added rear window handles to the pins which basically placed them just forward as the ones you would install from FFR. This also allowed me to install the midrange speaker and tweeter in that area where the handle would go.
  6. Thanks clays123 thanked for this post
    are you referring to these http://www.factoryfiveparts.com/6076...dles-set-of-2/
    Yep, I kind of like these. i was just wondering how difficult they are to retrofit.
    Quote Originally Posted by AJT '33 View Post
    This would be my 2nd option. Where did you purchase the handles?
    Is this car with the hard top? How come you dont have the pull handles where the mid range speakers are?
  10. #9
    Jun 2018
    Quote Originally Posted by clays123 View Post
    I wouldn't think a retrofit would be a problem at all as long as you can take the door panel off... I believe it works with the same latch mechanism...
  11. #10
    If memory serves me right I got them from Speedway, they are Lokar rear window crank handles. They have a bunch of styles, I replaced the pin that FFR provided and put in a pin that fits exact to the handle hole. A bolt and a bushing is what I had until I found the right stud that fit the existing hole and handle. The round of the handle covers the slotted plate they provide. I also had a $50 gift card which took a bit of the sting off the price, they are nice regardless.
    https://www.speedwaymotors.com/Lokar...ack,97701.html
    Last edited by AJT '33; 03-15-2019 at 10:14 AM. Reason: updated where I purchased the handles
  12. Thanks JimLev thanked for this post
    Likes FF33rod liked this post
  13. #11
    Is this car with the hard top? How come you don't have the pull handles where the mid range speakers are?
    I didnt like the look of any of the handles i saw, they all seemed normal or what everyone else had, If I would have found something maybe I would do it differently however this also allowed me to use that space for the stereo. I do have door openers/actuators with Billet Automotive push buttons I bought from Australia. I can push the button or reach over and manually open it or use the remote. Having three ways I thought would make it easy for me . I also have an emergency button that's hidden on the car that pops a door as well in case the battery dies.
    And yes I have a removable hard top as well.
  14. #12
    Jun 2018
    Isn't the button electric actuation? if so, how does that work if the battery dies?
  15. #13
    The door panels are already off, that's why I am looking at the different options right now.
    Thanks very much you have been most helpful.
  16. #14
    I didnt like the look of any of the handles i saw, they all seemed normal or what everyone else had, If I would have found something maybe I would do it differently however this also allowed me to use that space for the stereo. I do have door openers/actuators with Bullet Automotive push buttons I bought from Australia. I can push the button or reach over and manually open it or use the remote. Having three ways I thought would make it easy for me . I also have an emergency button that's hidden on the car that pops a door as well in case the battery dies.
    Thanks very much, obviously you put a lot of thought and effort into your build. You are most helpful.
  17. Thanks AJT '33 thanked for this post
    Likes AJT '33 liked this post
  18. #15
    Secondary power source adequate to activate the popper which is keyed and hidden. I also have two remote terminal posts that are keyed to allow for an external Lithium boost as well. I know its a lot of redundancy but for the sake of about $100 its worth not being stuck.
    Black & Copper ("The Mistress" as per my wife! ) #1028
    Brought home: Nov. 2017, GoKart: May 2018, Plated & on the Road: ??? 2019??
    Andreas
  19. Likes FF33rod liked this post
  20. #16
    May 2016
    North of sacramento Ca.
    I used these and was some work post 303 toms 33, but works good. The little handles just did not work.
  21. #17
    Quote Originally Posted by 1932 View Post
    You might want to check what Bill did on his post "Kit 075 restart" Post #470 (page 2), he used the FFR handle with the wire in a sleeve that goes from the door handle to the second hole of the latch on the inside of the door, you can see this in the attached picture from Bill. I know there is a better one but could not find it, this one looks easier to install. Good Luck!!
    Andreas
Levy Racing
