WTB: Titled, Sorted Roadster
I'm looking for a complete, registered, turnkey, sorted roadster. Looking to spend about $30,000. I would prefer dark blue with white stripes, silver or gray with stripes or burgandy with stripes. Had one picked out but deal fell through. Thank You !
You should have no trouble finding one, but be aware that it may take some time to find the "right" one for you.DSC_0058.jpg
*Ford 8.8 rear end with 3.08 gear ratio.
*5 lug 17x8 and 17x10.5 halibrand replica wheels wrapped in Toyo Extensa II tires.
*Whitby motors power booster brake kit.
*Ceramic coated headers and side pipes.
*Ron Francis complete wring harness.
*Breeze automotive brand new gas tank kit, radiator support bracket, aluminum fan shroud.
*Battery isolator key switch, remote battery jumper terminals.
*TKO 500 3:27 transmission, 31 spline 11.25” driveshaft, Powergrip 10.5 550hp clutch kit, McLeod 157 tooth steel flywheel.
*Ford 351w engine stroked to 396, Trick flow heads, full roller block,1 piece rear main, moly rings, holly double pumper carburetor, holly mechanical pump, MSD ignition system with rev limiter, 436hp with 448ft lb torque, engine has 5yr 50k mile Warranty.
*Starter Powermaster Mastertorque 9603.
*3 link rear, coil-overs all 4 corners.
*New North race cars Brake kit with 13” slotted rotors, front large GT twin piston calipers, rear twin piston calipers with mechanical E brake, factory five e brake handle kit.
*Custom FFMetal battery box with cover, Optima red top battery.
*Full leather interior and leather wrapped dash.
*AutoMeter ProComp Ultra Lite gauges.
*Aluminum dual row radiator with aluminum shroud, electric fan on 180 degree temp switch, aluminum overflow.
*Front oil cooler, auxiliary oil filter, braided lines with AN fittings.
