Thread: Lower FFR A frame bushings
    Kirkland, WA
    Anyone know where i can get new FFR A frame bushings ? or what size the bushing are ? Maybe the Energy Suspension (replacement for stock lower control arms) would fit? or I just go with http://www.factoryfiveparts.com/sphe...-control-arms/ and be done with it
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Fairfax Station VA
    If you need the metal insert, Breeze has them: https://www.breezeautomotive.com/sho...m-bushing-set/
    But personally, I'd go with the F5 spherical bearings.
    P.S. See how easy that was to spend your money?
    MK IV Roadster #8631
    Agreed. "or I just go with http://www.factoryfiveparts.com/sphe...-control-arms/ and be done with it" that is your answer.
    +3 on the new spherical bearings.
    I just finished installing them on my car. I haven't driven it yet, so no first hand performance experience to share. However, the install was easy enough, so you won't need a great deal of time to make the switch; especially considering you have to do most of the work to replace the original bushings regardless. Good luck!
