0
0
On another note...
I'm full of questions tonight! I'm usually full of something, but tonight it's just questions.
I had gotten the engine installed a couple of weeks ago. Finally got the driveshaft torqued down, got the Forte hybrid trans mount installed, and then install the trans "A" frame. At this point I became aware of the fact that the engine/trans as a unit is rotated down on the drivers side. I was going to hook up the hoist, loosen the bolts, and try to lift the drivers side back up to level it, but in checking the engine mounts, the locator pins have no more available space to allow them to rotate in the frame mounts.
What am I missing here? There must be some way to bring everything back to level side-to-side.
Any answers would help. I've run out of options, other than putting some spacers in the motor mounts.
Thanks.
Rick
