I probably should have posted this in the FIA section, but there's always more traffic here. I spoke with Mark at Breeze earlier, to ask about a problem installing the lower support for the radiator, and he let me know that he had been made aware of the issue by someone else building an FIA. The additional 3/4 tube that crosses low on the front of the frame, basically under the bottom of the radiator, interferes with the Breeze support. The lower petcock even hits that same 3/4 tube when you try to rotate the bottom of the radiator up on the piano hinge at the top. Has anyone building an FIA run into this, and if you did, how did you solve the issue of support for the bottom of the radiator? I installed the top per the recommendation of Mike Everson, except I removed the two small pieces of 3/4 tube that are welded under the upper 3/4 tube. Any ideas would be a big help right now. Thanks.
Rick
