0
0
Kit part included question
I pick up my R kit 13 April. I was reading the build manual and it states this:
Track only lower ride height - rear
Recommended parts
Heim Joint lateral links consisting of: (4) Swaged link tubes 12 inch long with ¾ fine thread (left hand/right hand) (2) 8.5 inch long 5/8 bolts for attaching rod ends to spindle (4) Left hand thread ¾ inch shank 5/8 inch bore rod ends w/jam nuts (4) Right hand thread ¾ inch shank 5/8 inch bore rod ends w/jam nuts (4) 2¾ inch long 5/8 inch bolts (6) 5/8 inch nuts (8) 5/8 inch inner diameter by 3/8 inch long spacers for rod ends. (2) Longer ½ inch grade 8 bolts for upper shock mounts. 5/8 inch Washers
Does this mean it doesn't come with the 2 lateral adjustable arms (ie. parts)?
Ed
