Results 1 to 3 of 3
Thread: Kit part included question
    Jan 2019
    I pick up my R kit 13 April. I was reading the build manual and it states this:
    Track only lower ride height - rear
    Recommended parts
    Heim Joint lateral links consisting of:  (4) Swaged link tubes 12 inch long with ¾ fine thread (left hand/right hand)  (2) 8.5 inch long 5/8 bolts for attaching rod ends to spindle  (4) Left hand thread ¾ inch shank 5/8 inch bore rod ends w/jam nuts  (4) Right hand thread ¾ inch shank 5/8 inch bore rod ends w/jam nuts  (4) 2¾ inch long 5/8 inch bolts  (6) 5/8 inch nuts  (8) 5/8 inch inner diameter by 3/8 inch long spacers for rod ends.  (2) Longer ½ inch grade 8 bolts for upper shock mounts.  5/8 inch Washers
    Does this mean it doesn't come with the 2 lateral adjustable arms (ie. parts)?
    Ed
    Bowling Green, KY
    No the kit is designed to use the OEM arms, FFR does sell an adjustable set. I believe most of the R guys are running what is described above. The swaged tubes and rodends ends and lock nuts I got from Speedway. The rest of the bolts I got from McMaster Carr.chassis left rear 2.JPGChassis left rear.JPG
    Jan 2019
