Grill from Breeze test fit
I just got my Breeze grill back from the powder coater, I got it anodized so it wouldn't corrode over time. The anodizing made it a little darker gray than the original silver aluminum color it was when I got it from breeze.
I think I'll install it with silicon or maybe automotive goop, any suggestions ??
I really like the look. Very finished. Might have to pick me one up!
Grills looks super. I do not have them in my plans, but after seeing yours, that is probably going to change. Just when I think I have settled on a color, you put that show stopper in my face. I am hoping you will give the color codes on both the body and stripe. I think all the post it notes on colors will get pulled down. I am impressed! Can you tell.
Every time I see that gray, I am stoked at how good it looks. And I dig the Breeze grill.
Originally Posted by
Railroad
Thanks. Here are the colors;
Paint , Ford , Ditzer PPG, RM BASF
Body – Sterling Gray Metallic, M7205, 919055, 765145
Stripes – Rubi Red Metallic, M7283 , 931662 , 883552
Stripes outline – Tuxedo Black Metallic, M7211, 918644, 765124
cv2065
Thanks, Ive been going back and forth, I really like the one Jazzman has on the flip top build but this will do. There is one for sale in the Part page on this forum.
Boydster
Shouldn't be long for you now, just in time for good weather.
I used strips of heavy duty exterior mounting tape so that I could remove it if needed (which I did need to to pull the radiator). I spent some time treaking the bend on the flange so that it laid flat on the body.
Looks great by the way.
Beautiful! Grill is a must have now.
