I'm looking to see if anyone has a OEM fuel pump control module I could use for testing before I drop a Benjamin on a new one. I'll be happy to cover shipping both way.
I'll take a look, I might have one.
I have from '03 Outback 3.0, not in front of me but I know where to find it in my pile of boxes. Part number ? If it fits you can have it.
Could not find fuel pump module. Might have gone with my second car to bfletcher.
Part numbers
104993-0430
22750AA010
Although I’d be happy to try any version, they all have the same plug, should at least let me know if the issue is FPCM or ECU.
I have 22750AA010, which is listed for 03,04 H6 Outback only. Your parts are for 06 and newer. These get a pump speed signal from the ECM, digital I believe. MIGHT work but I would not trust this for diagnostic purpose on a hunch.
22750AA010 is what was on my car when I got it, which means it should be what the initial builder pulled out of the donor. It was working just fine for a while. This website lists 22750AA010 as a 2004-2007 WRX STI Fuel Pump Control Module:
https://subieautoparts.com/product/2...-ecu-assembly/
So I'd like to give it a try if you are not using it.
I'll PM you my shipping information.
