Thanks Thanks:  2
Thread: Mk IV Anniversary Front Tires
    Heart of Dixie, Alabama
    Edwardb and War Eagle Scott, I am getting close to buying tires. I have been down this road previously, but misplaced my notes. I am running power steering, if that makes a difference. I would like to use BF Goodrich Rival S 1.5 tires.
    Looks like 245/40/18 front and 315/30/18 rear. Sizes are limited on this model tire, but I think I am within the accepted size, per your selections. Did either of you add or have to add steering limiters to your rack? I enjoy reading your post, but hope you do not mind helping with this. thanks,
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I'm not either of those guys, but I have studied their threads extensively and can confirm that the sizes you list are the sizes that Edwardb used in his build as I just purchased the same sizes. I'd also love to hear if rack limiters are needed for this setup though, as I haven't yet installed them on the car.
    I'll also point out that the Rival S 1.5 is a front-only tire. They don't make it in a 315 width, so if you're searching online you'll find the Rival S 1.5 in the 245/40R18 and the 'regular' Rival S in the 315/30R18 and it's OK to mix them.
  3. Thanks Railroad thanked for this post
    Right. Those are the sizes I'm using on my Anniversary Roadster. I added one limiter on each side of my Breeze sourced Unisteer PS rack.
  5. Thanks Railroad thanked for this post
  6. #4
    UPS man dropped these off yesterday. He commented on how light they are. This model tire is only available through Summit Racing. I tried to buy them local and even after calling Michelin, could not buy. No issues with Summit, they take my money quite often.
