Results 1 to 9 of 9
Thread: Flaring tool
    Accord NY
    Flaring tool
    I need to install the wiper kit and realized I need a flaring tool. I have read the other reviews and I see everyone loves the Eastwood tool for $180. Has anyone used a less expensive flaring tool that they like?
    thanks
    Craig
    Feb 2017
    If you don't need it to run actual brake lines then the quality does not matter nearly as much. As long as there are no burrs etc that interfere w the cable then a poor flare is fine. Just use the autoparts store loaner tool for free.
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Quote Originally Posted by frd2 View Post
    Agree.
    The Eastwood tool is great but not needed for your intended use since you do not need a tight seal.
    Lilburn, GA
    If you're wanting to flare the chrome tubes that come with the wiper kit, good luck. Several people, including myself, have tried with no success. The tubes are hard.... Not sure anyone has had success. If anyone has, please let the rest of us know what type of flare tool you used.
    Accord NY
    Hi Ducky2009, does that mean I do not need need to flare them? Its just cosmetic?
    Feb 2017
    do some searching - I think lots have used other materials. NiCop line, regular steel brake line, rigid plastic, some use short section of steel w a flare, then join with firm rubber in between (easy to route, etc) then back to steel w flare at the wheelhouse.
    Senior Member Norm B's Avatar
    The tubes have to be flared to anchor them to the wheel boxes and drive unit. Mine split when I tried to flare them. I don’t know if the supplied tubes have changed from 2012 when I got my kit but, they are too large of diameter to fit properly into the wheel boxes and allow the cable to flex around inside causing erratic wiper movement.
    If they are still the same I would recommend you take the cable ( or cut a small piece off the end ) with you to your favourite auto supply store that sells bulk brake lines and find a tube size that the cable just slides smooothly into.
    I have heard that the wiper kit has been improved. Hopefully this is no longer a problem. I spent a lot of time reshaping the wheel box attach points to get the cable to firmly engage the wheel and prevent skipping. They can now run on a dry windshield and not skip. Before anyone calls me out on that, I didn’t do it on purpose. My daughter wanted to listen to the stereo while I went into the gas station to pay and turned on the wipers instead of the aux power. When I came out the stereo was on and the wipers were happily sweeping the dry windshield. All switches are getting labeled bezels now.
    HTH
    Norm
    Lilburn, GA
    Quote Originally Posted by cfriedman67 View Post
    Yes they need flared. As others have said, use a different tube. I used steel brake lines.
    ALSO: The wire connectors are two different sizes (width). The narrow ones plug into the wiper motor and the wide width ones plug into the switch. The wide ones don't work well in the motor.... ask me how I know.
    A plug (not supplied) is available from Finish Line. $15 https://www.**********accessories.co...ical-plug.aspx
    Accord NY
    thanks all. I got it from here.
