Thread: Fuel lines for carburated 302
    Mar 2018
    Saint Johns, Florida
    Question Fuel lines for carburated 302
    Curious how you guys ran the fuel lines from the tank to the engine since the 302 fuel pump is on the driver's side (assuming, of course, you used the mechanical fuel pump, not so fond of electrical pumps). Also, I am not so fond of the fuel filter position in the manual; would rather have it in the engine compartment. So I thought I would run the fuel line (no return) next to the rear brake line on the driver's side main tube. Just wondering how to get the line from the pickup in the tank over to the driver's side. I will figure it out, just thought I would not re-invent the wheel if some did it before.
    Mar 2013
    Medway, MA
    3/8" ID Fuel Hose to cross over back and the tank then 3/8" OD hard line under the car and back to 3/8" ID fuel hose to jump from the hard line to the fuel pump inlet. From the pump 3/8" fuel hose to to a WIX 33003 filter and back to hose to the carb.
    Mar 2018
    Quote Originally Posted by Mark Reynolds View Post
    Thanks, Mark. Sounds great!
    Jax Beach, FL
    I am a fan of hard lines except where absolutely necessary. My line crosses over on the frame behind the passenger compartment, and then up the 4" tube on the drivers side next to the brake line.
    I did a big FRAM racing cartridge filter in the stock FFR location and an in-line one before the carb.
    The only flex hose I have is from the frame to the pump.
    Alliston, Ontario, Canada
    I did the same, hard line across frame behind pass compartment, under trunk, short flex line to pick up.
    Short braided flex line from drivers side 4” frame to mechanical fuel pump then inline filter between pump and carb.
    Also 3/8.
    Keep in mind that the filter should be on the pressure side of the pump, not the suction side.
