0
Green Testing Connectors and Jumper Location?
I stated using my Tactrix cable to try and tune my 2003 WRX(I think). I'm able to read the normal OBDII type data but having trouble with the reading and writing of the ecu flash. I think its associated with the green test connector that you have to connect and the jumper clip. I think the jumper clip is in the correct port. the 2002 .pdf wire diagram does not show the correct wire colors for some reason. I traced a wire from the obdII port and pin to the jumper connector and it should be correct.
My problem is I cannot find these additional green connectors. I guessing a made a big booboo. not sure where to start on this one as the wiring colors do not match up. I'm assuming the PO cut them or I did. Any ideas where I can trace these wires from? ugh.
