Results 1 to 2 of 2
Thread: Steering Shaft - FF Change Parts?
    Central Lake, MI
    Working on the steering shaft today and noticed my parts are different from what is described in the manual. I have two U Joints, one with a 36 spline end that appears to go on my power steering rack and another that is a 1" DD U Joint x 3/4" U Joint.
    I also have three separate lengths of shaft that appear to be 1) the hollow tubing the upper shaft goes into 2) the upper shaft and 3) the lower shaft.
    I have fitted everything together and it seems to work but I haven't seen this setup in anyone else's build yet. What I have seen is the U Joints welded to the lower shaft and the hollow DD tubing.
    Anyone else have this setup? Is it new?
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
    Yes. They went from the 2 piece design to several pieces. I believe this was done so that more of the parts can be used across there kit line.
