Thread: Removing the smog pump on a 92 5.0
    I removed the smog pump and now I have to block the holes in the back of the heads. Any suggestions on the best way to block them.
    5/8-11 bolts or setscrews.
    The heads fit on either side and are drilled + tapped front and back.
    When the holes are on the front of the head you often need to mount things there - alternator / power steering pump / etc.
    The part that fits and is threaded internally for mounting something else there is called a thermactor plug, and is commonly available (+ cheap) if you know exactly what you're looking for.
    https://www.google.com/search?q=ther...hrome&ie=UTF-8
    ty they almost looked threaded but I couldn't really tell.
    Mar 2013
    Fort Collins, Colorado
    I have to restore the smog system on my 89 Mustang. Want to sell the emissions that you took off ?
    Quote Originally Posted by Build14fun View Post
    Clean them up with parts cleaner and a small tooth brush, then blow them out, before threading the plugs in. They get carboned up.
    Quote Originally Posted by Derald Rice View Post
    Sure I will sell, what parts are you looking for.
