Question for the forum
I’m taking my time finishing the brake and fuel line routing and using SS for the hard lines. At the time I finished up the front section I used aluminum sleeves and tube nuts for connections to the -3 aluminum adapters shown. I really didn’t even realize that this might be an issue because it seemed to be sold as brake line compatible equipment.
I am planning on replacing with steel. After reading some other forum thoughts on this I figured I would ask.
I should replace these aluminum fittings/adaptors with steel, correct?
Is this a theoretical issue or actually known to cause failure?
