Thanks Thanks:  85
Likes Likes:  149
Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 593
Thread: MJS Mk4 Build Thread
  1. #201
    Dec 2018
    Hudsonville, MI
    Was able to get some work done on the trunk area again tonight. After I Cleco’d the trunk panel and drop trunk in place I went to secure the fuel lines and realized the access panel was too small and I couldn’t get a wrench to the connections. I decided I wanted to have a larger access panel over the fuel pump.
    Simple to do and lots of people have done this before.
    Access area before enlarging that I had put rivet nuts into.
    Outlined the new access area.
    Placed 8-32 SS rivnuts
    Coupe Kit Delivered 11/10/23
  2. Likes Straversi, PeteMeindl liked this post
  3. #202
    Nov 2018
    Great progress on the build, keep up the good work!
  4. Thanks MSumners thanked for this post
  5. #203
    Dec 2018
    Hudsonville, MI
    Nothing earth shattering but still plugging away when time allows. Working on the side trunk panels and got the RT signal positioned.
  6. #204
    Dec 2018
    Hudsonville, MI
    I’m planning on ordering some SS Gas’n sidepipes soon. The headers FF sends are shown below. I assume these will work, but what are advantages or disadvantages to using either these or the ones that Gas’n sells?
  7. #205
    Dec 2018
    Hudsonville, MI
  8. Likes Boydster liked this post
  9. #206
    Vero Beach FL
    Nice and clean! Love the PC color.
  10. Thanks MSumners thanked for this post
  11. #207
    Dec 2018
    Hudsonville, MI
    A Few Questions for the experienced here.
    1: I've never lifted an engine before. I acquired a hoist, leveler with chains and lifting plate. I assume I just remove the 4 nuts as shown, the EFI comes off and the plate bolts on? Is this the best way to go about this?
    2: Does anyone have a picture of how the underdash panel from Replicaparts fits in this area? I cant' see how it will work without cutting it up.
    3: I gently placed the steering wheel and hub on the upper steering shaft just to eyeball the gauge positions. I can't get it to slide down at all without starting to mar up the edges and start to create a ridge. It seems like one of the edges will have to be filed down a bit. Has anyone else run into this. I understand its not supposed to seat all the way in but the slotted area almost appears to be the least bit off with respect to the upper steering shaft.
    Thanks again for any guidance!
  12. #208
    Can't help you with the Replicaparts panel. Haven't used one. But for the other two -- Yes, a lifting plate on the intake works great. Seems a little scary hanging your engine and trans on there, but it's been done that way for decades and works very well. I've done it a bunch of times. You'll need to play around a little to see which hole gives the best balance location. I've typically used the front one. That's gives the best down angle to get the trans under the firewall, which may still need some pushing as you lower it into place. Some use a load leveler, but I haven't found that necessary when lifting from the carb location. Good luck.
    For the steering column and hub, yes it's a tight friction fit. If there are any burrs or whatever, yes clean them up. But with the aluminum hub over the steel shaft, normally it will make its way in place using the mounting screw and a large washer. Then it will be tight with zero slop, which is exactly what you want. In my experience, once in place, you won't get it back off without using a puller. So be warned.
  13. #209
    On my #9042, the Replicaparts underdash panel fit perfect. I believe F5 made changes to the steering support bracket since mine, and chances are that Mikes panel is designed for the older setup. You probably just have to do some small trimming to make it fit.
    But I would check with Mike first. He may have a more detailed answer.
  14. #210
    Dec 2018
    Hudsonville, MI
    Will do, thanks again for the info and I’ll check with Mike. Just wanted to make sure I wasn’t missing something obvious or fitting it wrong somehow.
  15. #211
    Dec 2018
    Hudsonville, MI
    Preparing to possibly install the engine and trans tomorrow and I was reviewing the manual and some build threads. For the transmission mount do I need the plate labeled ‘1’ below? I can’t seem to find it and don’t see anything similar in build pictures I reviewed.
  16. Thanks Aircontroller thanked for this post
    Likes Aircontroller liked this post
  17. #212
    Not required for your engine. Used on Coyote and (I think) mod motors because they're not as long. But for sure not yours.
  18. Thanks Aircontroller thanked for this post
  19. #213
    Senior Member Traveller's Avatar
    Jul 2019
    Grand Rapids, MI
    Mike - I'm around this afternoon / evening, so if you do install the motor today let me know if you want an extra set of hands.
    -Jason
    MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
    Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
    Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
  20. #214
    Dec 2018
    Hudsonville, MI
    With the help of my old man and a fellow forum member (thanks Jason) we were able to get the engine and trans in without any issues.
    I do have a question about the engine mounts where they meet up to the chassis mount as shown below.
    On each side there is about 0.5-1mm space between contact at only the front edge of the mount. On both sides the pins are in the correct slots. The transmission is at the correct height with the 0.75 spacer and appears aligned. The distorted lock nuts have not been tightened down yet.
    Before tightening these down I figured I would ask, should these be completely flush? Something else I'm missing or should check?
  21. #215
    Dec 2018
    Hudsonville, MI
    To answer my own question, after the trans was raised to the correct height for pinion angle and the distorted lock nuts are turned down all is flat, solid and well.
  22. #216
    Jul 2019
    Grand Rapids, MI
    Glad to hear it, Mike. I enjoyed helping you get that motor put in place. You've got a great looking build! Looking forward to hearing you go-karting around the area soon.
  23. #217
    Dec 2018
    Hudsonville, MI
  24. Likes Aircontroller, timmil liked this post
  25. #218
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Damn that looks good! I love the simplicity of a pushrod Ford motor in the engine bay!
  26. #219
    Jun 2019
    Las Vegas, NV
  27. #220
    Looks really good. I'm assuming you're going to take it back out to finish the DS footbox? Might be possible to rivet the inside pieces with the engine there. But wouldn't be particularly easy IMO. Very common to leave the outer top and outside side pieces off until the very last, e.g. right before the body goes on. But the inside not so much. Also, I'd recommend going ahead and bending your dash ends. You'll need to trim some length off on the PS to clear the short firewall piece on that side. Not required to trim the length on the DS, but I do just to keep things simpler. Maybe you already know all that.
  28. #221
    Dec 2018
    Hudsonville, MI
    Good eye and thanks for looking out! The footbox was actually overlooked. I did realize it afterwards and looked at the clearance for getting rivets in place. The DS footbox is actually no problem but the U shaped piece in front of the trans cover is. I'm going to cleco everything in place and determine exactly what I can and cannot reach. If the direction of the rivets bothers me too much I'll just pull the engine partially out while I rivet them in place. Possibly I'll just use the black head rivets from Mcmaster and not worry about it because the only ones I can't reach will basically be hidden by the engine and body.
    Thanks for the recommendation on the dash ends. I'm just starting to work on the dash and was determining fitment and where to bend them. They essentially just bend behind the hinges? I was tentatively planning on bending them around a small paint can. I just received supplies of carbon and leather and plan to work on the dash concurrently with finishing off fuel lines to the engine and working on the wiring harness. I'm fully prepared for the dash to be similar to the brake lines in that it'll likely be the third or fourth iteration I ultimately keep.
  29. #222
    Dec 2018
    Hudsonville, MI
    I haven’t actually raised the tail of the transmission to the adequate height yet for pinion angle but noticed that the SFI bell housing does hang below the frame. It appears with adequate spacing on the trans it will be close, as others have encountered. It will likely be close to 1.25” spacer
    If I have to trim the lower lip of the bell housing a bit, is the plasma cutter the way to go?
    If so any recommendations?
  30. #223
    I cut mine with an air cut off tool. Cleaned/straightened with a belt sander, and touched up with black paint. Even a Dremel with a cut-off wheel could be used, but might go through a couple wheels. It's pretty tough. Plasma cutter would be a little overkill and rough IMO. But that's me. Plus I don't have one... I've had to do it a couple times. I cut it even with the level of the oil pan. So it's not the lowest point not matter what. Both of those were with Moroso pans on a Coyote, so may not be exactly the same with your setup.
  31. Thanks MSumners thanked for this post
  32. #224
    Mark Eaton's Avatar
    Medford, Oregon
    MSummers,
    x2 on what Paul said, plasma cutter is definitely over kill but if it fits into the budget they are a lot of fun to use on other projects! Another tool which will trim the bell housing is an angle grinder such as this one
    https://www.homedepot.com/p/DEWALT-1...402W/206743975
    These tools are super handy for these builds if you don't already have one.
  33. #225
    Senior Member cv2065's Avatar
    I've had my angle grinder and cut off wheel from Harbor Freight for 7 years...and they are still chugging. Save some money and take a visit if you have one close by. The only thing I wouldn't buy from there are portable, battery driven tools, but then again, HF is getting some upgraded versions of those as well.
  34. #226
    Dec 2018
    Hudsonville, MI
    Thank you gentlemen. Sounds like I don't 'have' to buy a plasma cutter yet, but also seems like so much fun. I actually do have the same dewalt angle grinder and have found it useful for so many things in this build so far. I agree very useful. Once I get the panels figured out, riveted and trans raised appropriately I'll decide how much to take off. Initially looking at the bell housing it looks like a major thing to cut but sounds like it goes reasonably well with the cutoff tool.
    Thanks again!
  35. #227
    Dec 2018
    Hudsonville, MI
    Some slow but steady progress. Had the engine back out while I riveted in the drivers side footbox and went back in without any drama.
    After looking at the driveshaft angle and spacing I thought would be adequate I ended up needing a taller spacer on the transmission mount. It was cheap to buy a 1.25” section of 6061 aluminum from onlinemetals to exactly the right length so that’s what I did to make a new spacer.
    After securing the mount in and loosely attaching the driveshaft I checked the driveshaft angle with the iPhone TREMEC app and appears to be within range. If anyone sees anything else I should check please let me know.
  36. #228
    Dec 2018
    Hudsonville, MI
    Anyone have recommendations for an adhesive for dash work?
    I just acquired all the supplies and it’s planned to be a combination of layers; Aluminum,carbon,leather.
    Thanks for any tips.
  37. #229
    Dec 2018
    Hudsonville, MI
    Went to install the Metco driveshaft safety loop this evening. With the lower support mount flush and in place, I ended up with only about 3mm of clearance between the loop and the driveshaft as shown.
    Is this typical or should spacing be a bit more?
  38. #230
    I've used multiple times and highly recommend DAP Weldwood Landau Top & Trim HHR Contact Cement. It's a professional product and used extensively in automotive and trip shops. If you've watched any of the car shows on TV (or seen in person) where they're spraying adhesive using a gun for interior work, 99.9% chance it was this stuff. I've found it can be brushed like regular contact cement. It flashes off very rapidly and makes a permanent bond. If you know someone at a local shop, you could maybe get a small quantity. They get it in large cans. Or you can buy gallons online. I haven't seen it in any retail stores. Not cheap but works as good as anything I've tried. I get it here: https://www.yourautotrim.com/noname37.html. There are also a number of different 3M (and perhaps other brands) spray can products. Others can recommend what works best for them. I've tried several and not nearly as happy with them as the DAP Landau product. Plus you really have to watch the overspray. It's a bit messy.
    Yeah, that's too tight. Many of us have put spacers between the bottom bracket and the loop. May need to get longer bolts as a result. Will raise the loop up over the driveshaft to a more acceptable gap. Just visible in this pic.
  39. #231
    Dec 2018
    Hudsonville, MI
    Thanks for the recommendations again. I bought a gallon of the dap adhesive mentioned as that was the smallest one I could find and I should probably be set for life on that.
    Added some spacers to the safety loop.
    Good clearance?
  40. #232
    That spacing on the driveshaft loop with IRS should be fine. You're right, a gallon of that DAP adhesive should last a while. Just make sure to keep it well sealed. The solvent will evaporate and it can become unusable if you don't. Has happened to me. Also use it with a lot of ventilation. You'll see what I mean when you use it.
  41. #233
    Dec 2018
    Hudsonville, MI
    This is about the point I decided the air rivet gun was a wise purchase.
  42. Likes Boydster liked this post
  43. #234
    Dec 2018
    Hudsonville, MI
    Almost ready for lizard skin. Going to spend some time sealing up all of the small gaps and then masking everything off.
  44. #235
    Vero Beach FL
    That’s good looking. Too bad it gets covered up.
  45. #236
    Dec 2018
    Hudsonville, MI
    Masking and lizard skin day. Spraying sound control and I’ll do the insulation Saturday.
  46. #237
    Dec 2018
    Hudsonville, MI
    The lizard skin experience. I initially ordered the lizard skin set of sound control and ceramic insulation with the plan to get it sprayed when the weather was warmer. It does state in the instructions that it should be at least 60 degrees to set up correctly. I ended up taking longer, as usual, and getting sidetracked doing the drop trunk, switching out the fuel pump etc.
    so ultimately I was ready to mask everything off and do the insulation but the snow is flying. I decided to heat the garage and get the spraying done but after the second coat 1- my 100lb propane tank ran dry and almost immediately blew a breaker and lost power. This left it sitting overnight at about 30degrees. I came back to it expecting to see a disaster but mostly it still set up well. There were 2 small areas that peeled away and may have been in fact some degree of silicone I didn’t completely get removed.
    I still have to spray the ceramic insulation and will just focus this up front and in the foot boxes. I think I’ll probably do a small area of dynamat where I had trouble spraying around the DS
    Notes about the lizard skin
    1- disassemble and clean the spray gun extensively after every coat.
    2- the recommended 55psi seemed to work very well.
    3- between masking and spraying I probably have about 18 hours into this process so I’m not sure if it’s a time saver at all over other methods but have nothing to compare to.
    Any recommendations on what to do with the small areas that peeled up, if anything?
  47. #238
    Hard to say what happened there. As you said, the surface could have been contaminated. The way it's cracked though, almost seemed like a curing issue which could be related to the low temps. Perhaps it was thicker there, which wouldn't be unusual in a corner like that. Personally, I'd scrape off what's loose and re-apply a few layers with a brush. It's in an area that won't be seen, plus covered by more coating and carpet. Shouldn't be an issue. Good luck with your next step. FWIW, long term forecasts show slightly warmer temps. But we're off to an early cold start here in MI.
  48. #239
    Dec 2018
    Hudsonville, MI
    Thanks for the advice!
    I’m still working on putting lizard skin down in 2 small areas that wanted to peel up. In the downtime I started working on the power steering lines. As usual I consulted Mark at Breeze and he set me up great fittings. All of his solutions always work perfect.
    Below is how I created and ran the high pressure PS lines. There is plenty of clearance around the steering shaft and belt. Nothing is tightened down yet.
    If anyone sees any issues let me know.
  49. #240
    Dec 2018
    Hudsonville, MI
    For the driveshaft adaptor, two different lengths of bolts were included. As others have noted, the longer set bottomed out prior to being fully seated. Instead of using the shorter set I ground the tip off of the longer bolts just enough to get full engagement and no bottoming out. I only had to take off <1/16.
