Results 1 to 12 of 12
Thread: Koni Rear Shock Install
    Mar 2017
    I've seen some conflicting pictures and instruction so here's my stupid question for the day.
    Are the rear shocks supposed to be installed with the red body uo or down?
    The RED shocks can be mounted either way.
    I installed mine with the hat on the top and the threaded collar on the bottom.
    You can see them on the attached video between 40-50 seconds in.
    https://youtu.be/PCngiKoopkA
    Good Luck From The Dark Dart Side!
    Parker, CO
    Check out my build thread starting on post #32.
    https://thefactoryfiveforum.com/show...l=1#post285839
    I originally installed per the version of the manual I received, but the springs were way too close to the brackets. After consulting with the experts, I flipped the rear shocks over and all was good.
    I did the same as Papa... originally installed per manual, then inverted them for clearance. Straight axle rear.
    Body down.
    Parker, CO
    Boyd makes a good point by referencing that this is for a solid axle. What rear suspension are you building? Regardless, the red-body Koni shocks can be mounted with the body in either orientation (up or down). The double adjustable Koni shocks must be oriented a specific way.
    Body down.
    Like The Chevy Guy Did!
    Sorry Jeff, but you know I had to!
    Mar 2017
    Thanks for all the info gentlemen. For the record I've got the Independent Suspension Rear.
    Body up 'if' you don't have a clearance issue, a slight improvement of less sprung weight.
    To avoid questions of your car details in the future go to the top right of this page and click 'Settings'. Scroll down the left side and click 'Edit Signature'. Type in all your car details and click 'Save Signature'.
    slpro1207's Avatar
    Moorpark, CA
    You might think about including your city and state. If you have folks close by and need help you and get several offers. Especially when beer is offered.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Kearney Nebraska
    I might add, when I was installing mine someone pointed out that with the spring down there's potential for the brake lines to get inside the the coils of the shock while it's going thru it's cycles. That was the main reason I went body down.
    Serial #9158
