Is it possible to accurately paint on racing stripes with the body off? Has anyone successfully done it? If, so, how would you go about it?
Yes, you need to have the hood and trunk lid properly centered in the body so that the stripes will be aligned across those panels. We used masking tape to hold the hood and trunk in the proper position while we laid out the stripes.
Wade
Yep! Like they said. Shoot stripe color down the center, Set hood and deck in place with some foam strips to hold up level, set the gaps ,tape in place, mask stripes, cut gaps, remove parts, finish taping, shoot body color, unmask stripes, clearcoat . When you put your hood and deck on when you are done you only need to line the stripes up,,,gaps will take care of themselves...da Bat...….at least I think that's what they said....right?
Anyone have a recipe for how to paint racing stripes on a car that has already been painted and clearcoated? My original plan was to have the stripes laid on at a vinyl wrap shop. But they are having problems doing it so I may have to resort to painting them on. I really do not want to have to redo the whole car. Any suggestions. I did all the paint work myself so I'd be doing the stripes myself as well. I've never done them before so any help would be greatly appreciated.
Paul
You can do the stripes in single stage. You will have a small edge but not much diff from vinyl. Mask it off, scuff with 600 or 800 shoot, peel and drive.
Am I the only one who thinks those gorgeously sexy curves are better revealed without the distraction of the straight lines of racing stripes?
But, I do agree that they great advantage FFR cars have is that they are all built to the individual tastes of their owners. And, that's a good thing.
Thanks guys for the recommendations. Sounds like single stage it the way to go. Do you guys have any tips, tricks , hacks on how to scuff up the paint at the edges of the masking lines without damaging the masking lines. Or do I have to lay it out, scuff it up, remove it then redo the masking? Thanks again for sharing your knowledges and expertise.
Paul
