I need to order the hood latches. Is anyone using something different than the Originals?
I'm leaning towards these from Amazon for a modern style lock.
https://www.amazon.com/dp/B07B4ZKNNY...v_ov_lig_dp_it
Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
Kevin
MKIV #8234
I too am more of a traditionalist. In addition, I use the latches only to hold the hood closed, not lock it. I have never used the locks.
Kevin
MKIV #8234
I would never consider something with a 3 star or less rating. If you want that style latch, try looking at places like Summit, Jegs, or Speedway to see if you can get better quality.
I am also in the that is not what belongs on a Cobra camp. But, it's your car.
I have locked mine when staying overnight in a hotel. I make sure that I unlock them before driving the car in case emergency access is needed.
Revising my question then.
Does anyone use a High Quality, billet machined, USA made Hood latch that looks a little more modern?
Breeze Automotive had a hidden latch
https://youtu.be/VYdecHf4Su0
