Results 1 to 3 of 3
Thread: Hallibrand Valve Stems
    May 2018
    Merritt Island, FL
    Any recommendations for tire valve stems for the Hallibrand repro wheels?
    Alliston, Ontario, Canada
    Mine came with some. Of course I found them and lug nuts after I had bought some and had them installed.
    Check all the little boxes for the lug nut covers. Mine were all in one I hadn’t opened.
    So. Bay (So. Calif.)
    Here's a thread of mine from a couple of years ago. The FFR supplied stems just didn't quite fit. https://thefactoryfiveforum.com/show...nd-valve-stems
