Results 1 to 6 of 6
Thread: Mk4 irs battery box
    Mar 2018
    Saint Johns, Florida
    Question Mk4 irs battery box
    Well...i went to FFMetals to get a dropped battery box and found out they don't have one for MK4 with IRS after 2017.
    Anyone find/make a dropped battery box for their MK4?
    Also, looks like a battery could mount just behind the pumpkin on the crossbar. However, access later could be dicey.
    Highly recommend the Breeze front battery box. https://www.breezeautomotive.com/sho...-1-4-roadster/
    Yep, as Paul suggested just go to the front.
    Mar 2018
    Thanks, Paul and Jeff. That's the best plan.
    I think FFmetals is working on a two 6 Volt battery solution but hasn't finalized it yet.
    BadAsp427's Avatar
    Greeneville, TN
    Check out this thread... May find you can do the rear mount battery...
