Results 1 to 2 of 2
Thread: Windsheld Support arms not parallel
    mcwho's Avatar
    DeBary - Florida
    please see posts at "lexan windsheild question" thread
    https://thefactoryfiveforum.com/show...hield-question
    I have the fast freddies kit, and have re checked my measurements with the windsheild off. Wondering if anyone else has done the measurement of the windsheild support arms. I measured the inside and outside level surfaces with laser devices used for wheel alignments. apparently the two that i have are not parallel and i believe that they should be. The edge at the top of the arm does or did not alingn up correctly and dont understand why this would happen as they are connected to the frame.
    Before I mount the Lexan windsheild, I want to verify whats wrong here so that I dont have another cracked windsheild..
    Baghdad Bob
    Fairfax Station VA
    I would be very surprised if the frame mounting plates were parallel. Off just even a tiny bit at the bottom will equate to a rather large difference 1 1/2 feet later. You can find out if the plates are parallel using some steel or aluminum bar. Or you can skip the test and gently bend and/or twist the chrome-plated brass windshield arms to get them where you want them. Make all bends & twists below the body level using rags to keep the chrome from getting scratched up.
    Though the lexan won't crack it's best to minimize any preload stress.
    MK IV Roadster #8631
