Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Oil pump recommendation
    Jun 2015
    Fairfax Station VA
    While swapping out my oil pan & pickup, I broke the cheap-a$$ pot metal housing on the oil pump. So now I need a new one. I went to Napa and bought this one: https://www.napaonline.com/en/p/SEP22441118 but now I'm second-guessing that decision.
    Any body got a favorite oil pump for a Ford 302? And should I replace the oil pump shaft while I'm doing? This is for a street machine, though I might do an autocross just to find out what it takes / feels like to spin.
    MK IV Roadster #8631
    Aug 2012
    Grand Rapids, MI
    I've used Precision Pumps http://stores.precisionoilpumps.com/
    Basically a smoothed out Melling or similar. Has worked well for me. Not sure on the drive shaft, ARP maybe? Sorry, can't remember.
    Jim
  3. Thanks phileas_fogg thanked for this post
    Melling standard volume performance oil pump 10687.
    https://www.summitracing.com/parts/m...view/make/ford
  5. Thanks phileas_fogg thanked for this post
